Grizzly won't rev
Old Dec 12, 2005 | 03:14 PM
itsback's Avatar
Default Grizzly won't rev
Originally posted by: pads
Actually, I was wrong. If putting your hand over the intake made it run okay, then it is a fuel problem. Does running with the choke on make it run better. The choke is just a fuel enricher. If it does run better with the choke on, then it is definetly a fuel problem. Also, check your spark plug and see what color it is. Mabye, change it to eliminate as a possible problem.
Last night I did find an online sevice manual and decided to disconnect the reverse sensor lead just to see what it would do. With it disconnected it did not run any better but once I reconnected it allowed it to rev with out having to cover anything up. It did rev but not near as quickly as it had before. I took it out and rode it for over 15 minutes having to disconnect and reconnect the lead 4 times at fairly even intervals. However in between having to unplug the lead i had to play with the choke, the longer I rode it the more frequently I had to adjust it. At times it ran the best with full choke others with none at all. I did try covering up the intake again and but it did not help nearly as well as before. I really need to get it running correctly soon and this combination I found to work for a while, before running low on gas, has me thinking it could be a combination of the reverse sensor and not enough fuel.
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
