banshee prob
Old Dec 20, 2005 | 09:34 PM
kess's Avatar
Default banshee prob
i was riding today and all of a sudden my right exaust stopped doing any thing and i lost power but it still ran fine
does this just mean i need a new plug its pretty new
Old Dec 20, 2005 | 11:14 PM
farmerjohn's Avatar
use periods or something. it makes it hard to read for dummies like me
sorry can't answer your question
Old Dec 20, 2005 | 11:19 PM
IdahoVinnie's Avatar
You forgot a period after "me".
LOL (I just had to mention that.)
Old Dec 27, 2005 | 08:44 PM
BADSHEE's Avatar
Change your plug, look at the plug to see if it is full of metal.
if that doesnt fix it do a compression test if you have over 80 psi it should be firing.
If that still doesn't fix it there is a screw next to the drain on the bottom of each carb, unscrew it with the gas on to see if you have flow if you do and your still not getting fuel check to see if the jet is clogged.
If all this is over your head bring it to the dealer.
Old Dec 27, 2005 | 09:02 PM
midnite's Avatar
You say you lost power, but every thing still ran fine? Switch your plug wires {l to r, r to l} and see if the problem switches sides. This won't harm your motor since your coil fires both plugs at the same time on every stroke. If the problem switches sides, it is a plug wire or cap. If it doesn't, disconnect your little black tors box {above left cylinder on frame}. If it still doesn't run right, check your reeds.
Kaleb_00
Jun 1, 2016 09:15 AM
BigCam
Sep 16, 2015 01:53 AM
toonces
Aug 5, 2015 05:55 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
