warrior help please
Old Dec 27, 2005 | 07:23 PM
lfowarrior's Avatar
Default warrior help please
My warrior is running like crap,it will run great if you put a new plug in it but if you shut it off it wont start back up.I thought it was the parking brake so i put a brake block off on and unpluged the sensor,i thought it was the carb so i took it apart and it looked fine,i also took the gas tank off and flushed and cleaned it but it still wont start up on a used plug.The starter clutch rattles or clunks when you try to start it could that be my problem.It dont make any sense to me why it will run fine on a new plug but thats it. PLEASE HELP
Old Dec 27, 2005 | 09:03 PM
FalconFan's Avatar
sounds like you might have bad spark look at the coil and you voltage, might not be firing right.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
