Raptor 350 - difficult shifter - suggestions?
I have a 2004 Raptor 350. Been a great, reliable ride. This past trip, the shifter became really stiff and wouldn't shift into neutral. Really tough to shift from gear to gear. Once it sat for about an hour, the shifter was fine again. What's happening here?
Any suggestions appreciated.
maybe a bearing got metal shavings in it and went bad. I don't know how likely it is that the shaft actually got bent, because the rappy350 doesn't have a direct linkage, it has one of yamaha's sloppy linkages that should have broke before any damage occured inside the motor. An oil change wound't hurt, but this sounds to me like something in the transmission is broke or bent and binding up.
Njrider1230
07-29-2023 05:16 AM
