450 kodiak no fire
Old Dec 28, 2005 | 08:27 AM
willywonka's Avatar
Default 450 kodiak no fire
hi i have a 2003 kodiak 450 and it quit on me the other day and when i checked it out and i have no fire. i checked all that i knew of and sent it to a guy who workes on bikes and he can't figure out what is wrong. one question i have is how can u tell if your cdi is gone and can you test it .
thanks.
Old Dec 28, 2005 | 11:18 AM
MonsterMotorSports's Avatar
Check your spark plug wire for any cracks follow it al lthe way back and check it all over, i know its a long shot but it happened to me i had no spark could not figure out why found out there was a short way back in the wire. good luck
Old Dec 28, 2005 | 12:52 PM
hondabuster's Avatar
Theres not a way to check the cdi, other to swap it into another working quad. Usually in the troubleshooting, if everything else checks ok, then the cdi is bad. Theres a list of things to check in the service manual.
What are the circumstances of the dead motor? You were holding it wide open at 55 and it quit? You stopped for a break and it wouldnt come back on? You were stuck in a mudhole and it shut off?
Tried bypassing the kill switch? New spark plug? Checked connectors for haveing water in them.
Does the starter spin the motor, and theres just no spark? Is there spark using the rope pull?
Old Dec 28, 2005 | 12:57 PM
willywonka's Avatar
i was doing around 30 or 40 and it just died and i checked the wires and tested the coil and statorfor ohms. it turns over good but just no spark. there is a guy i know workin on it and he said he did all he knows but can't figure it out. it is a mystery to me. thanks for the help.
Old Dec 28, 2005 | 01:50 PM
Try a new plug and see if itll spark by using the rope pull.
Make sure the kill switch is in run.
Check the fuse, the ign fuse, and the main fuse.
Check the resistance of the spark plug cap...should be about 10k ohms.
Then its on to checking the ohms of the coil, primary and seconadry sides, and then the stator. pickup coil resistance of the white/red to the white /greeen, should be 459 to 561 ohms, at 68 degrees.
Let us know what is found.
Old Jun 30, 2007 | 09:17 PM
BroakenYak's Avatar
What was the fix and what was the problem? I'm having the same issue and need your thoughts.
ultangler
Nov 30, 2024 01:35 AM
mrtidy
Feb 3, 2016 05:00 PM
YankeeRebel
Oct 6, 2015 06:44 AM
IMLN
Sep 28, 2015 03:32 PM
Elkaholic
Sep 6, 2015 02:44 PM
