raptor pistons??
raptor pistons??
ok im about to switch out my cam to a hotcam stage 1.. since im going to have my engine apart i was thinkning about puttin in a piston kit like this one...... is this piston for a stock bore? do i have to bore it out and make it bigger? or is thi pisotn just a straight drop in to the stock engine? with any other mods? also will this psiton make a good combo with the hotcam stage 1?
thks guys im clueless when it comes to internal engine parts.
raptor pistons??
If you're clueless you probably dont want to be doing this on your own. I dont see any link to a piston so I cant answer much. Any stock bore piston will at least need the cylinder honed before it can be installed assuming the stock cylinder is still small enough to accomodate another stock sized piston without blowbye.
raptor pistons??
raptor pistons??
thats exactly what i want to do..i dont want to bore it bigger etc..i just want a better performing piston and just drop it in...im going to get the hotcam stage 1 and wanted to get an aftermarket piston to just drop it in without having to do anyting else since i have the engine apart.
yeah i was looking at the CP pistons also..i might get them.
raptor pistons??
I'm doing the exact same thing. I'm having a shop do it for me, though. What I want to do is just drop in a stock-bore piston with new rings and gaskets. I won't know if I can do this until they take the head off and tell me what the cylinder looks like. If I don't have to bore it, I'm going to drop a stage 1 hotcam in as well.
I'm probably going to go with Wiseco for the piston. How about their gaskets? Should I buy Yamaha gaskets? Is there a better piston too?
raptor pistons??
exmotocrosser
09-13-2019 06:12 AM
Quadzilla Heritage
09-25-2015 01:39 PM
