Raptor gearing
Old Jan 21, 2006 | 05:26 PM
04RaptorLE's Avatar
Default Raptor gearing
I am just wondering if I dropped a tooth in the front will it get me out of the hole alot quicker or should I stay with stock gearing,also will it help keep the front end down on the ground? My buddy has a modded YFZ450 with exhaust,airbox mods and cam mod I am trying to get the jump on him and stay ahead of him. Right now if we leave at the same time I can hold him off until 3rd then he starts to pull me,thats is assuming I can keep the front end down.I have tried taking off in 2nd and it didnt seem to help.Not worried about top speed I am also thinking that the lower gear will help on the trails that I ride and keep me from shifting so much.
One other ? I am thinking of going with the Stage 1 cam will I notice a difference? If so where lower or upper end,and is it a drop in only or will I have to do work to the motor. Wanting more power but I want to keep my quad reliable as well. Thanks for any help
Old Jan 21, 2006 | 05:34 PM
thedieselkid's Avatar
you will leave the line faster, but your front wheels will come up much easier.
Old Jan 21, 2006 | 11:40 PM
Raptor350rider14's Avatar
go up a tooth, thats what i did, and the stage one cam is awesome, atleast for my 350, i think it will only be better for the 660. with the cam and the extra tooth on the front u will be able to keep up with him and keep the wheels down, but easily bring them up when u want to.
Old Jan 22, 2006 | 01:40 PM
dragraceraptor's Avatar
Yeah, Go up one tooth,thats what I did on my pipe raptor and it helps alot.You dont lose any take off, because you shift less and the motor is enough strong to pull te 5th gear easily. Good luck for beating that yfz[img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Old Jan 22, 2006 | 07:25 PM
04RaptorLE's Avatar
Wont going up a gear make it lug more on the trails. I ride tight trails and some wide open and second seems to be the best gear but it seems a bit high and 1st to low. I might by 1 over and 1 under stock gearing and see which works best. I gues they dont really cost that much..
DragraceRaptor how do you like the stage 1 cam and did it make a noticable difference? Thanks for all the info.
Old Jan 22, 2006 | 09:47 PM
YFZRyderMace's Avatar
Going up 1 tooth will help you get off the line faster because it will keep you from spinning bad. Going down a tooth will cause you to spin more but it will go through the gears a little quicker (better excelleration). As far as trail riding the Raptor is a torque machine so going up one tooth wont hurt you much and going down will help with slow speed trail riding... Mace
Old Jan 23, 2006 | 09:28 PM
No I dont have the stage one yet,I'm going to buy it in 1 or 2 months. Can't you read, it says soon hahaha jk dude
But i'll let you know how it works peace
Joel
Firefighter400
Oct 8, 2022 06:38 PM
Ashley S
May 29, 2017 10:54 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
black_thunder
Jul 9, 2015 05:58 PM
