Kodiak 450 oil change
You can drain the oil thru either of the two drain holes in the bottom of the engine. Im assuming the one under the dipstick area, is the one thats blocked. If so, theres a much larger plug in the center of the engine case. Careful when unscrewing it...theres a strong spring underneath it.
If you go to the ronnies part finder, look in the oil pump diagram, and its number 15.
ronnies
ronnies
Elkaholic
09-06-2015 02:44 PM
