Blaster does not smoke a lot
Old Jan 23, 2006 | 12:19 AM
RedneckRacer64's Avatar
Default Blaster does not smoke a lot
I have a ques. I have an 05 Blaster with: a Pro Circuit pipe, Dyno Jets, Bosen Reeds, K&N Air Filter, and a Vitos Big Bore Kit. It does not smoke hadly at all. I'm running 32:1 Ratio. Is that normal to not smoke a lot. Thanks
Old Jan 24, 2006 | 11:08 PM
Storj's Avatar
I run 32:1 and after my blaster is warmed up it doesnt smoke at all. But im using synthetic oil.
Old Jan 24, 2006 | 11:40 PM
That's the same I run. I run castor 927 32:1.
Old Jan 24, 2006 | 11:41 PM
That's the same that I use. I run 32:1 castor 927, and my bike does the same as yours. I guess that it is normal.
Old Jan 25, 2006 | 07:31 PM
rruser's Avatar
Its normal for 2 stroke motors not to smoke as much once warm.
This is because low crank RPM causes less mixing/air flow in the crank case. This causes more oil mix to coat the crank/crank cases but, when you rev the motor up the oil will become suspended again and burned. The exra oil that has been collecting at low RPMs is what makes the most smoke. This is also why its better to use a lower gear when cruising to keep the mix suspended.
As with any tuned motor, a spark plug and compression check should be done as part of normal matinace.
Old Jan 25, 2006 | 08:28 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
hey, if it ain't smoking don't question it, its usually good if it doesn't smoke. :-)
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
