frustrated beyond beleif
Old Feb 1, 2006 | 05:41 PM
trialsrider172's Avatar
Default frustrated beyond beleif
i heated the axle housing, not the axle it self....why would i heat the axle... u cant really heat the bearing cause on one side u have the break rotor (the side thats its really stuck on) and the other side, which isnt really stuck... u get the bearring warmer heating the axle housing rather then just one end of the bearring...even though i still heated the end of the bearing also
Old Feb 1, 2006 | 06:46 PM
smb05's Avatar
trialsrider172,
If you are anywhere near a Harbor Freight Tools go buy yourself a slide hammer. Slide Hammer Or if you know someone who has one. It will pull right out no heating required.
Old Feb 1, 2006 | 06:56 PM
now thats some good advice that is much apreciated right there. it might not have enough force though, i mean, if a sledge hammer cant do it, a slide hammer may not work...but i'll try anything at this point. thanks smb. i'll ask my neighbor if hes got one, hes got every tool under the sun
Old Feb 1, 2006 | 07:52 PM
smb05's Avatar
trialsrider172,
I guarantee it will pull your axles out with no problem.
Good Luck.
SB.
Old Feb 1, 2006 | 09:15 PM
  #15
good try smb, but theres no way to hook it up to the axle, and the sledge hammer i was using has more force then that could anyways...this things really stuck
Old Feb 4, 2006 | 11:06 AM
  #16
i finally got it out with a bigger hammer and a bigger vice.... : ) on with the restoration
greg74
Sep 10, 2019 03:03 PM
txpedsrt1
Feb 3, 2017 08:07 PM
Whitelx1
Oct 2, 2015 10:55 PM
toonces
Aug 21, 2015 01:19 PM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
