Warrior Cold Starting Problems
Old Feb 23, 2006 | 03:36 PM
jaggers2e42's Avatar
Default Warrior Cold Starting Problems
Originally posted by: YamahaRider8998
doesnt the edelbrock carb help alot with cold starting?
i don't know but i would love to find out[img]i/expressions/face-icon-small-cool.gif[/img] i have wanted one for a while now.
Old Feb 23, 2006 | 06:08 PM
recon99's Avatar
When the edel is dialed in right cold starting is much easier than the stock carb. There's no choke, all you do is pump the throttle 4 or 5 times to let the accel pump prime it, and hit the starter button. In really cold weather sometimes it takes a 2nd try, but usually it'll go by itself the first time. I love it!
Old Feb 23, 2006 | 10:32 PM
warpigs's Avatar
I never noticed this before, but after I did the motor the header glows red when the choke is on, worse in the winter, also because the piston is a JE lightweight forging with the small diameter rings, the thing does smoke a little oil until it warms. I contacted JE and they said that that was normal due to the more expantion of a forged piston, and the wider clearences.
Old Feb 23, 2006 | 10:40 PM
recon99's Avatar
Are you sure your jetting is right? A glowing header is sometimes a sign that you're too lean. Cold starting can also be more difficult if you're too lean.
Old Feb 24, 2006 | 04:00 PM
  #15
warpigs's Avatar
Mabe the pilot jet isn't right? I thought the main had noting to do with starting or ideling.
Old Feb 24, 2006 | 04:29 PM
  #16
recon99's Avatar
The pilot jet is what controls the starting and idling, but if the pilot is off, chances are the rest of the jetting is also lean.
MikeyBoyesq
Nov 27, 2020 02:44 PM
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
