Raptor clutch problem
Old Feb 22, 2006 | 02:14 PM
GregP's Avatar
Default Raptor clutch problem
Put in a new EBC clutch in an '02 Raptor - last couple of times out it worked flawlessly. However, this past weekend had a major problem. I was on a ride - it seemed to be working fine - we can to a stop for a rest and suddenly there was no tension whatsoever on the clutch lever. Checked the clutch cable - the arm connects to etc. - nothing out of the ordinary. Was able to pop it into first without a clutch and make it back to camp. At camp - disconnected the cable and pulled the shaft it connects to out and reset it. After reconnecting the cable - we were able to restore enough tension to disengage the clutch. Took it out on another ride - samething happened again - only this time was unable to restore tension. I haven't pulled the clutch apart yet - was curious if anyone has experienced a similiar problem - I thinking maybe something with the bearing on the shaft inside the clutch cover. Any ideas?
Thanks,
Greg
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
coolguy420
Jul 10, 2015 01:17 AM
Sjrpp
Jul 5, 2015 09:04 PM
yambam13
Jul 4, 2015 01:49 PM
