Blaster oil pump question
Old Mar 9, 2006 | 05:58 AM
lethaface's Avatar
Default Blaster oil pump question
Originally posted by: recon99
Maybe you were jetted too lean and something melted, causing it to seize, but I don't think it would have seized just because it wasn't broken in.
I agree..My bet is it was either a failed pump(only a plastic gear) or more likely it was a air leak..
Old Mar 9, 2006 | 03:01 PM
TwinCam95's Avatar
I'll check the color of the new plug I put in when my new piston comes in tomorrow. I plan to run it on pre-mixed gas and have it idle with the oil tube off the carb and the carb plugged. There's a certain amount of oil it should pump each 200 pump strokes, so I'll accomplish both things at once. I'll let you all know how it turns out.
Old Mar 11, 2006 | 02:32 AM
TwinCam95's Avatar
Got the new top end in....
The oil pump checks out fine
The jetting is perfect
the bike runs like a champ
The only change in setup between now and when it blew up was the brand of piston. The one that siezed was a Wiseco, and the one I put in is a WSM. Maybe it was just a bad piston.
Thanks for all the helpful suggestions. -Randy
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
Mikea1978
Jul 4, 2015 12:37 PM
