warrior rear brake
Old Mar 12, 2006 | 12:50 PM
trialsrider172's Avatar
Default warrior rear brake
the bolt with the allen head that the caliper slides on is seized up...tried everything to get it loose.
any suggestions past PB blaster and lots of force?
it does have to be loose so that the brake can line up right?
Old Mar 12, 2006 | 01:02 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
are yo usure you're going the right way? it doesn't take much force to get those 2 bolts out
Old Mar 12, 2006 | 02:17 PM
unless its a left hand thread, yes, we are going the right way...me and my dad tried turning the wrench together at the same time
its loose on the bracket but its stuck in the caliper body it self
Old Mar 12, 2006 | 02:21 PM
recon99's Avatar
I don't really have any ideas for you, other than maybe try using sharp quick blows to it instead of excessive force, sort of like how an impact wrench works to break things loose. Maybe try tapping it with a hammer or something. Or just let the penetrating lube soak in for a few days, and try it again.
Old Mar 12, 2006 | 02:44 PM
UltimateAussie's Avatar
yeah i would try quick sharp blows on it, if you know someone with access to air tools that has an impact wrench i would use it, but be carefull with how much force you put on that bolt the stock bolts on my warrior are really soft, i have broken several.
good luck
Old Mar 12, 2006 | 03:16 PM
alright, i'll try again later, lettin the PB soak in alittle longer
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
