not sure about warrior rear brake caliper
Old Mar 14, 2006 | 10:52 PM
trialsrider172's Avatar
Default not sure about warrior rear brake caliper
ok, i already posted about this but i thought maybe i could get some new info...warriors have floating calipers or what ever its called so i got on of the allen screws loose and it moves up and down like its suppose to, but theres another allen screw with a rubber boot around it. are BOTH of them suppose to move or just one? i just cant get one to budge!
Old Mar 15, 2006 | 06:23 PM
madmad's Avatar
What are you trying to do? If you are removing the caliper to replace your pads, there is two hex head bolts you have to remove to get the caliper off, then the two allen screws come out so you can get the pads out.
Old Mar 15, 2006 | 07:41 PM
recon99's Avatar
are you working on the front or rear caliper?
Old Mar 15, 2006 | 08:31 PM
i probubly should have specify that it is the rear...i'm not trying to change the pads, no, its just that the quad has been sitting a very long time and my dad said both of these things are suppose to slide up and down to align the brake against the disk so it doesnt bend the disc...theres 2 allen bolts, one is loose, the other is not, and i dont know if it really is suppose to or not...my dad thinks it should, and i guess it makes sence too, but it was in a rubber boot and everything, but wont budge.
Old Mar 15, 2006 | 09:20 PM
recon99's Avatar
Ok, I know what you mean, that screw should come out.
Old Mar 15, 2006 | 11:05 PM
it finally did come out after 3 nights of hitting and squeezing and everything else...all thats left is putting the brakes back on, tightening up some swing arm bolts, and riding!!!
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Reactant
Jul 16, 2015 10:29 PM
