does the raptor have the throttle screw on it
Ummm??? to adjust the idle or to limit the throttle so you dont go gettin wild on his craptor? there is one screw on the left side of the carbs for idle adjustment and then one on the back of the thumb throttle for limiting the amount of go the bike has.
throttle housing
That's on my warrior, but it's a similar setup. In that picture you can see the head of a screw sticking out of the throttle housing, pointing towards the brake lever. That's the limiting screw. Loosen the nut at the base of the screw, turn the screw in until it limits the throttle the desired amount, then hold the screw in place while you tighten the nut back up.
