Odd clutch problem terra pro
Old Mar 25, 2006 | 10:15 PM
nailzscott's Avatar
Default Odd clutch problem terra pro
I am looking at a used Yamaha terra pro but it has a very strange problem. Without pulling the clutch lever you can put it into gear. When you pull in on the clutch lever, then it starts to move. It's almost like the clutch is working in reverse. Any ideas?
Old Mar 25, 2006 | 10:40 PM
recon99's Avatar
Do you have any more information about it? Like does the clutch slip under load, did the problem happen all at once, etc.
Old Mar 26, 2006 | 11:31 AM
nailzscott's Avatar
I have not bought the atv yet, it is at a tractor dealer (who knows nothing about atv's) - he got it as a partial trade-in. It has been sitting for around 7 months at the dealer. He thought it worked OK when he took it in trade, but he could not be sure. With it sitting at idol, you do not have to pull the clutch lever to put it in gear - it just does not move. Then pull on the clutch lever and it starts to move. It is not fully engage because it doesn't just jump off the start. It is just acting the reverse as it should. I should have to pull in on the clutch lever, put it in gear, release the clutch lever, and take off. It has been a few years since I tore down a clutch on a motorcycle, but this is just not right.
Old Mar 26, 2006 | 12:59 PM
recon99's Avatar
The only thing I can think of is maybe if someone tried to repair the clutch and assembled it wrong, or if something broke apart in the clutch. I don't know much about these terra pro things though, to be honest I never even heard of it before.
Old Mar 26, 2006 | 09:08 PM
nailzscott's Avatar
Thanks for trying to help. The terra pro is really pretty cool. It has a PTO and some attachments were available. This particular one comes with a 42" bush hog.
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
