wierd doubt
Old Mar 28, 2006 | 10:56 PM
escuchopeliculas's Avatar
Default wierd doubt
Right so I'm the kid thats gonna build a go-kart with an atv engine in it. I was checking around the forums and I ran into quadbart's post on how he put a gsxr1000 engine into his raptor. This is where my doubts come in. The reason why I was looking into an ATV engine was because the can go pretty fast and still climb steep things or get over obstacles fairly easy. Quadbart's engine pulls 230HP. That will make it go very fast in a very short amout of time, BUT will it still have the ability to do serious offroading??
I ask because it would be a heeluva lot cheaper for me to use a street bike engine plus I could go bigger with the money I save but I don't want to scrifice torque in the process.
Thanks
Andrea
Old Mar 28, 2006 | 11:26 PM
1bad450r's Avatar
Default wierd doubt
What kind of quad engine would you be running and what kinda of street bike engine would you consider running?
Old Mar 28, 2006 | 11:29 PM
Default wierd doubt
I was planning on getting something bigger than 600cc may a raptor 660 (expensive and hard to get) Same thing either way i want to stuff the biggest engine that I can afford without sacrificing speed OR power. Probably if its a street engine ill go 1000ish
Andrea
Old Mar 29, 2006 | 01:35 AM
recon99's Avatar
Default wierd doubt
If you geared the bike engine way low it'll probably work fine, the biggest problem other than size is that they have very tall and spaced out gears
Old Mar 29, 2006 | 01:41 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default wierd doubt
i think that once i get some metal fabrication skills under my belt i am going to build a go cart chassis that can withstand the punishment... it will pretty much be a side by side with better suspension and a LOT more power... pretty much just a mini dune buggy
Old Apr 2, 2006 | 08:30 PM
Default wierd doubt
Speedy: thats exactly my plan. to build something pretty hard core.
Recon99: How difficult (or expensive) would it be to have one of these engines re-geared? Do you think theres any other options out there that I could consider? I really want a good balance between speed and torque.
Thanks
Andrea
Old Apr 2, 2006 | 08:38 PM
Speedy2222's Avatar
Default wierd doubt
http://www.klondyke.net/lar456/KartLatestPic.jpg
that is what i am building... except the a arms they use is a 1 to 2
i am going to use pretty much everything off of a 660r
i figured it would cost about $1500 to build.
Old Apr 2, 2006 | 08:47 PM
recon99's Avatar
Default wierd doubt
You wouldn't really have to do anything to the internals, it's just a matter of getting a sprocket combination that gives you a lower final drive ratio. It may be difficult to find a sprocket setup for a sportbike that gives it a gear ratio low enough for off-roading though, so you might end up having to get one modified or custom made by a machine shop.
Old Apr 2, 2006 | 08:59 PM
Speedy2222's Avatar
Default wierd doubt
you don't want to use a street bike motor... trust me...
Old Apr 2, 2006 | 10:13 PM
Default wierd doubt
Why not??
What would you guys recomend? What do you think a good power plant would be for my application. (8ft long go kart, meant for serious abuse, want lots of speed but also lots of power for riding trails and climbing steep hills.)
