1998 warrior
Old Mar 30, 2006 | 04:42 PM
Warriorbabe's Avatar
Default 1998 warrior
I have a 98' Yamaha Warrior and I have a problem, so if anyone can help would nice I just got
it back from the shop and they told there wasn't anything wrong with it, But I would like to
have your opnion on what you all think. Here's the problem it want come out of reverse if in
gear and the only way I can get out of reverse if I shut off engine It want even got in neutral
when I put in reverse. I had the engine checked out because it was knocking loud and they
said all engines on atv's knock so help with that too.
Thanks
WarriorBabe
Old Mar 30, 2006 | 05:24 PM
recon99's Avatar
The trouble with getting it back into gear from reverse is common, it's from the clutch dragging, you could try a better oil like amsoil if you're not already. Also, when I was having this problem I found that revving the engine usually worked to get it back into gear, instead of shutting it off.
How bad is the knocking sound? Some ticking or tapping in the top of the engine is normal, but if you have a serious knock like a hard metal-on-metal sound you might want to take it to another shop. It could be bad bearings or piston slap if it's more than just ticking and tapping.
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Slagpolaris
Sep 5, 2015 09:41 PM
