Blaster Jetting
Old Nov 16, 2000 | 01:25 PM
pudjumper's Avatar
Can anyone help with jetting a blaster with a fatty pipe and a rad valve? What is stock jetting? What jet size would be a good starting for mods mentioned at '700 above sea level. Any help would be greatly appreciated.
Old Nov 17, 2000 | 12:32 AM
pudjumper's Avatar
Old Nov 17, 2000 | 01:24 AM
blaster10's Avatar
stock jetting for the main jet is a 230 needle clip is in the #2 ,the pilot is a 32.5 I would go up to a 260 or 270 main.(get both) and the needle clip in the #3 pos.pilot if you need I think is like a 30 or something,I'll check it out!
Old Nov 17, 2000 | 09:17 PM
Rob4092's Avatar
Pudjumper:
I can answer this for you as I have just experienced the same issue.
I put a FMF Fatty on my son's 98 Blaster. We ride at sea level (close enough to 700 ft.).
I called FMF and told them what I had. They told me to set it up as follows:
270 Main
35 Pilot (Idle)
Needle Clip in the stock position
Remove Air Box Snrokle (only)
The stock set-up is 230 Main, 32.5 Pilot and Needle Clip in the second from the top.
I would set your up the same as mine since we are close to the same elevation.
Good luck!
ReconBayou
Oct 31, 2022 05:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
nastyblaster100
Sep 13, 2015 01:19 PM
