Raptor 660 carb setting with open air box.
Old Apr 9, 2006 | 08:36 AM
azark's Avatar
Default Raptor 660 carb setting with open air box.
Hi,
I have some trouble with my 660.
The beast is like that :
CDI, FMF Q2, Twinair, Dynojet (144 & 146).
I have an EHS cover on the box, but the acceleration is not smooth ...
I have heard it was cause that the carb had not enough fuel.
At the moment, the "fuel/air" screw is set as dynojet recommand, saying 3 turns right from full left..
Any body could help me ?
Old Apr 9, 2006 | 10:09 AM
dragraceraptor's Avatar
With the dynojet kit,youre supoded to change the needles in the 2 carbs,put the different springs and on the different clip i think?If it doesn't work,I think you should go with the 146/148,thats what I have and it works properly...
just my 0.02$ though
Joel
Old Apr 10, 2006 | 05:31 AM
azark's Avatar
Yep, I did change all things provided with the kit ...
When I tested it (and get the non-smooth acceleration), I used the config for stock pipe below 3000 m altitude (I didn't have the Q2 yet)...
Next week end, I will then try the 146-148 with the open air box...
I let you know [img]i/expressions/face-icon-small-wink.gif[/img]
Thanx for the answer.
Jaycee.
Old Apr 10, 2006 | 05:53 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Jaycee.
what drag said....
i suggest you get it dialed with the airbox lid on 1st,,,,and then go from there
did you remove the flange inside the snorkel?
Old Apr 10, 2006 | 08:07 AM
oups,I forgot to say to you to cut the piece of rubber in the snorkle.my bad haa
Old Apr 10, 2006 | 08:09 AM
and what kind of cdi do you have?does it work good or not?Maybe its the cdi that gives you a non-smooth acceleration? just giving you some ideas...
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
Jul 5, 2015 09:04 PM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
