Carb Questions?
Old Apr 12, 2006 | 05:10 PM
TylerAnders's Avatar
Default Carb Questions?
Has any one ever herd of running 2 stroke carbs on a 4 stroke bike is there any way to set them up will it work. I need to put bigger carbs on my raptor and i have a set of old banshee carbs 35mm sittin in the shop and i was wondering if there is any way to set them up where it will work? thanks for any help
Old Apr 12, 2006 | 10:04 PM
rruser's Avatar
It could be setup to work but, it may not be worth the trouble/problems:
1) Lack of a accelerator pump alone could make it bog worse than your stock carb(s).
2) You will need to tune the carb from the ground up, pilot, slide, needle, main.
3) Because 2 strokes have a lower air velocity for their size, A lot of 2 stroke carbs will have a small sloted cylinder on the top of the needle jet. I'm not sure how big if a problem this would be..
For something like a raptor 660, I don't think it would be worth messing around with... unless you can get your hands on some baseline settings. Are you sure you need a bigger set carbs?
Old Apr 12, 2006 | 10:59 PM
Thanks and yeah i'm pretty sure i will havent got bike completely back together yet but I have a 720 kit and boondockers 20 shot what do you think i should run carb wise?
Old Apr 13, 2006 | 08:31 AM
maddog56's Avatar
Either get the stockers bored and increase the flow ability or step up to a set of dual FCR's.
Old Apr 16, 2006 | 04:11 AM
does any one know if i Can i get 2 stock carbs from a yfz 450 and run them, wil ti work with the hot start cableand the TPS wiring harness?do they need to be taken off or what?
Old Apr 16, 2006 | 07:38 AM
2FAST4U69's Avatar
You're in for a lot of headaches! If I were you I would either check ebay or save up some money and do it right!
Old Apr 16, 2006 | 12:00 PM
y would it be a headache? what is the diffrence in the dual 39 fcr kit that is sold for a raptor, and the stock carbs off of the 450
Old Apr 16, 2006 | 12:14 PM
maddog56's Avatar
A few hundred dollars in parts to make them work together and a lot of down time.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
