700r rear brake pads - wearing out
Old 04-18-2006, 06:44 AM
quadbike's Avatar
Default 700r rear brake pads - wearing out
Just wondering if any one else has had the same issues. I have gone through 4 sets of rear pads in about 200 hours of riding [img]i/expressions/face-icon-small-sad.gif[/img] The last set went over the Easter break. We did about 250km of hard riding on beach track and mud and the pad is down to the metal. As you look at the back of the quad, the left pad is at about 20% and the right side is down to metal.
The 700 has a self adjusting park brake. I think this must be over tightening and causing the pads to wear. The front pads are still at about 80% and I do not ride the brake, I am paranoid that I dont touch it with my boot.
Any ideas?
Old 04-18-2006, 08:23 AM
Scooter86's Avatar
Knows Old ATV Questions!
The parking brake is probably a contributing factor. In my experience, rear pads usually don't last as long as the fronts anyways though. Mud really chews through pads too. One suggestion, switch to EBC Severe Duty pads or something similar and see if that helps out.
Old 04-19-2006, 07:53 AM
quadbike's Avatar
I have a set of sintered metal pads that I am about to put in. I think I will disconnect the park brake as well.
Old 04-19-2006, 09:15 PM
recon99's Avatar
Unless you bent the rotor it's probably that useless parking brake that yamaha insists on installing on every quad.
Old 04-20-2006, 12:11 AM
Glamis700's Avatar
I mostly use the rear brake. My pads are good after about 10 desert trips.
Ive actually removed my parking brake all together. I installed a 2 bolt block off plate. It cleans up the appearance and loses 2 lbs at the same time.
Old 04-20-2006, 12:21 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
metal to metal works good.. especially when your rear disk is already f'd up....
Old 04-20-2006, 12:32 AM
recon99's Avatar
Yeah, that's the ticket! I did that for a while, the sparks looked pretty cool at night, but it made a hellish sound.
Old 04-20-2006, 04:11 AM
quadbike's Avatar
Well Im trying to hastle Yamaha about this. I dont know how I will go "bashing my head against a brick wall" I think. I will let you know if I get any where with it.
I will be asking for a new rear disk and pads...
Old 04-20-2006, 04:14 AM
quadbike's Avatar
Hey Glamis do you have a link to the block off plate or know where I can get it? Was it on ebay?
Old 04-20-2006, 02:10 PM
recon99's Avatar
You can get block off plates anywhere - local dealers, ebay, or just about any website that sells atv accessories will have them.
Quick Reply: 700r rear brake pads - wearing out
