raptor rear axle bearing question... please help
i need axle bearings in my raptor. i called dealer and they said it will be between 200-400 to do them. i said F that and im doin them myself. they said its about 100 for bearings seals and the shim. how hard is it to do them. ive done them on my blaster & warrior befor, but the carrier looks alot different than my blasters and warriors does. what is different about them and how will it be different when i do the bearins and stuff.
thanks
jeff
thanks
jeff
Ohh.. and how difficult is it? Pull your axle and extract the bearings and insert the new bearings and dust covers. depending on the amount of water you have ridden in... It could be a pain in the monkey *** or easy... Im not sure what the dealer is sayin a shim for?
The raptor isnt a whole lot different. besides the carrier is inside the swing arm.. Im pretty sure you can replace the bearings in the bike. But if you have to take it out it could be major pain. We took my carrier outand it was not cooperative about comming apart. If you have done axle bearings in one sport quad you can do them in any sport quad. They are all pretty much the same thing unless it has tapered bearings. wich a raptor doesnt so piece of cake. For 30 buck you get the dust covers and bearings. and thats all you need.if everything goes good it should take less than an hour. if not so good who knows [img]i/expressions/face-icon-small-sad.gif[/img]
Originally posted by: fastblaster00
how do u get the carrior out of the swing arm?
