Water in raptor Headlights. Normal?
Old Nov 19, 2000 | 01:17 AM
Raptzor's Avatar
I have water in my headlights. Called dealer and he said he thinks it normal but if that true that suck. For that much money you would think that would'nt happen.
Old Nov 19, 2000 | 06:29 AM
Juvenile's Avatar
Your dealer is trying to pull a fast one on you. I wash my Raptor after every ride with a pressure washer and there isn't any water in the headlights. I would get that fixed A.S.A.P!!!
j/t
01 Raptor Blk/White
Old Nov 19, 2000 | 11:53 AM
chop's Avatar
Raptzor,it could be condensation build up.i bought a DS a week ago and when i hauled it home on trailer the headlight had a little moisture build up in it. i started the bike and turned on the headlight and the moisture finally disappeared.i think its just not a good seal on the light is why this happens.disasemble your light and with your finger run a real thin layer of clear silicon around the seals.this should stop the moisture.i had the same thing happen on the stater case of my banshee.it got to where if you turned a certain way it would cut out and what it was the case didnt have a good seal and it was drawing moisture.after i put silicon on the case seal ive had no problem and this has been about 6 months ago.hope i could help,good luck.
Old Nov 19, 2000 | 12:43 PM
Majorecho's Avatar
Hey Chop,
If you pull your headlight on the DS you'll find a hole about a half inch in diameter,to the side of where the electrical connections come in - why it's there I don't know, maybe ventilation, but every time I pressure washed my bike I got moisture in it. I put a plug in it 6 mos ago - no more moisture -no adverse affects.
Old Nov 19, 2000 | 02:06 PM
coryatver's Avatar
My friends raptor blew his bulbs out becuase of moisture. i think it is normal.
Old Nov 19, 2000 | 09:17 PM
WhittD's Avatar
my raptor blew its headlights because of moisture too. i think it is pretty normal but my dealer is going to replace them.
Old Nov 20, 2000 | 09:42 AM
RaPtOrRiDr01's Avatar
Mine had moisture in it the first time i washed it and i didn't even use full power on my garden hose! I guess this may be normal cause it happens on my buddies 400ex also. I will run some silicone around it because i just don't like it when it happens.
Old Nov 24, 2000 | 12:25 AM
Raptorpilot's Avatar
Yes they do get moist in there, take it from me.
I had it under water. Only a little bit got in the right one, but it caused condensation. Remove your lights and pull the black housings apart. Apply dielectric grease to the bulb socket, and make sure you clean the halogen bulb glass clean with contact cleaner, to remove residue from your hand. Apply grease to the rubber headlight boot.
this will create a gasket/moisure barrier. that should doi it. do the tailight as well. Enjoy
2quiker
Mar 22, 2022 08:36 PM
quickwhips
Sep 2, 2015 06:53 AM
Aug 25, 2015 11:16 PM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 9, 2015 05:58 PM
