Weird High Speed Vibration on Raptor
Old May 5, 2006 | 01:55 AM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Default Weird High Speed Vibration on Raptor
Originally posted by: j87w
I found the rear hubs to be loose. So I searched around and found out they come loose alot on Raptors. I guess Ill be retorqueing them alot. Do you guys think this is what is causing the vibration?
Thats what makes mine shake like fat girl to rap music [img]i/expressions/face-icon-small-blush.gif[/img]
Old May 5, 2006 | 07:45 AM
Starky's Avatar
Sounds like you have a lot of stuff loose but I bet it's due to the shaking and not necessarily causing it. Try jacking up the rear end and run it in 3rd or 4th gear. If it's the axle or your rear tires you will see them shaking. Have somebody sit on it and hold the front brake in case it jumps off the jack.
Also, jack up the front end and have somebody hold the handlebars steady while you try and turn the front tires. You'll be able to see if there is any slop in your steering.
Old May 5, 2006 | 08:52 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Originally posted by: warwgn
bent axel or wheel, or the wheels and tires are way out of balance.
what he said
my raptor shakes quite a bit too,,,,feels like i am riding down the center of the train tracks at 50mph and up
I havent even bothered to see what the cause is, not yet anyway. Its either my holeshots are rejects,,,rim out of round (this is what i suspect on mine,,,left front),,,,,or a bent axle.
OFC,,why would loose hubs cause a shake. How loose are you talking?
Old May 5, 2006 | 11:12 AM
Monkey Rider
Afro-Engineer
The splines on my hubs are about half stripped [img]i/expressions/face-icon-small-sad.gif[/img] allotta miles of beating the chit outta it and you know how i am.. I break stuff [img]i/expressions/face-icon-small-smile.gif[/img] On the outside of the tire there is about 1/2"-1" of play in the splines. Its significant. So in effect that makes me ride off center in my wheels. also my T9baja's have always had a bit of a shake to them anyway. and they are always full of dirt and rocks. thats prolly added stress on the splines when the come loose. I really need new hubs and locktight on my axle bolts.
Old May 5, 2006 | 04:00 PM
  #15
j87w's Avatar
Ive jacked the front up and checked for play there and there was not any play at all.
On a side note, does anyone know if there is supposed to be a washer that goes under the cotter key bolt on the ball joint?
When I get out of work Ill try tightening up the hubs and going for a ride and seeing what that does.
Ill be back with an update. Thanks guys.
Nondem
Feb 22, 2020 12:20 PM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 28, 2015 11:05 PM
bpegram84
Jul 22, 2015 08:15 AM
hondarider1234
Jul 21, 2015 11:53 PM
