Warrior tranny pop
Old May 7, 2006 | 06:29 PM
01warriorutah's Avatar
Default Warrior tranny pop
I have an 01 warrior that pops out gear (2nd to neutral) under load ie: at the dunes. It will also miss a shift (3rd-2nd) every now an then. I had a 97 warrior that did the same thing. Is this a common thing or am I just cursed?
Old May 7, 2006 | 07:36 PM
badaceds650's Avatar
syncro and fork are wore out
Old May 7, 2006 | 07:43 PM
recon99's Avatar
First thing to do is check that the drive select (forward-reverse) is fully engaged, this could cause it to pop out of gear sometimes. Other than that it's not a normal thing, probably a bent shift fork.
Reactant
Mar 30, 2022 02:08 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Logan Collins
Sep 5, 2015 08:03 PM
