Tie Down Points
Old Jul 6, 2006 | 10:49 PM
Boosh71's Avatar
Default Tie Down Points
Do you have a picture of your trailer? Do you tie your quads down perpendicular to the trailer?
Old Jul 6, 2006 | 11:10 PM
Broadjumper's Avatar
I do a few things to ensure that my machine stays put. First I installed two Pringle front wheel chocks that are bolted down to the trailer. I make sure that the machine is fully engaged into the chocks then I ratchet a special strap between each corner of the front frame bar to the D rings I installed in the front corners of the trailer. These straps have hooks and an extra nylon loop on one end that loop around the machine frame member so that the hooks aren't in direct contact with the frame but engage the extra loop on the strap. I follow the same proceedure for the rear of the machine and I make sure that I have drawn the straps tight enough to pull the suspension down about 2". Finally I make sure that I set my parking brake and have my machine in park.
Never had a problem with this set-up.
Old Jul 7, 2006 | 04:38 AM
warriorguy22's Avatar
Good lord...thats not going anywhere, you can never be too careful I guess. I usually just slide mine sideways on the trailer and tie to the front bumper and the grab bar.
Old Jul 7, 2006 | 04:28 PM
deanz400's Avatar
I'll try and get some pics up ,now that I have a digatal camera , I'll put it on and take some pics ,my trailers are custom made stricktly for ATV's .more tie down points you have the more options you have for secureing them down ,
But I do say keep the tires from moving and the suspension can bounce all it wants .
ReconBayou
Oct 31, 2022 05:37 PM
Customer Service #1
May 15, 2020 08:46 AM
EIF
Apr 20, 2017 07:15 PM
bigred20653
Oct 2, 2015 10:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
