How much?
Old May 11, 2006 | 09:27 PM
recon99's Avatar
Default How much?
Yeah, it's exactly like what honda is doing.
For a sport quad the warrior handles great in tight trails. They have a lot of low rpm grunt that the newer machines don't have. It's still wider than your recon, has less ground clearance, and has a manual clutch, so it's not going to be as good as the recon in tight trails, but once you get used to it you'll be fine.
Old May 11, 2006 | 09:40 PM
hillclimbingrecon's Avatar
Default How much?
how steep of a hill canit climb?
Old May 11, 2006 | 10:40 PM
recon99's Avatar
Default How much?
Depends on how good your tires are, and how ballsy you are. They have a heavy engine positioned towards the front of the frame so the front end likes to stay on the ground, which is great for hillclimbs, and they have lots of torque so it's got enough power to pull almost any hill.
Old May 11, 2006 | 10:43 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
Default How much?
I got a Raptor 350 n I climp some pretty damm step hills w/ it, it will take pretty much anything you through at it.
P.S.
A Raptor 350 is basically just a Warrior in disguise.
Old May 11, 2006 | 11:01 PM
  #15
Default How much?
well like what? like 89 deggreehils?
Old May 11, 2006 | 11:17 PM
  #16
ATVrider89's Avatar
Default How much?
Ok first of all 90 degree's is straight up, I don't think there is any quad out there that can climb a friggen 89 degree hill, I'm talking maybee sumthin like maybee a 70 degree hill? I can't give a degree but the hill was pretty damm steep.
Old May 12, 2006 | 09:13 PM
  #17
Default How much?
I know 90deggrees is stright up "I am not that stupid" and about the 889deggree hill i was just pullin your leg!!How deep can you get before it bogs out?I am talking about mu/water? And would a stock one be able to keep up with a 450r/400ex/300ex?
Old May 12, 2006 | 10:48 PM
  #18
YamahaRider8998's Avatar
Default How much?
i have a warrior and it is a monster, i have went up long steep rocky muddy hills with no trouble, and my tires arnt even good they are half treads all tracs. It has never lifted up on me and never gives up no matter how long or steep the hill is, just stay in first and take your time.
steve
Old May 12, 2006 | 10:52 PM
  #19
Default How much?
the airbox is right under the seat, u can go to there with out any problems, ive dont it, she never gives up, i was floating in a mudpit that flooded and it just kept goin till i was out, it was about 4 feet cause i remember i leaned back so the airbox went higer into the air so it could go right through, just one thing i also have a disc exhaust so there isnt any big hole for water to get into, idk if that could be a problem.
