blue smoke
Old May 17, 2006 | 02:05 PM
Lukemysta66's Avatar
Default blue smoke
blue smoke does that mean oil burning?
Old May 17, 2006 | 03:16 PM
gassrx's Avatar
Default blue smoke
what is it on 2 stroke or 4 stroke
Old May 17, 2006 | 04:38 PM
quicksilver's Avatar
Default blue smoke
blue smoke is oil burning.
If you have a 2-stroke, oil burning is normal operation and essential to proper lubrication
If you have a 4-stroke, they arent supposed to smoke and if it is, you have bad piston rings or worn valve guides/seals, or you're sucking oil through your breather tube. Could also be an over-oiled air filter.
Old May 17, 2006 | 05:12 PM
Default blue smoke
yes it is a 4 stroke so it is not normal. maybe the guy i got it from might have had a bad mix of gas.
Old May 18, 2006 | 10:14 AM
RadRaptor's Avatar
Default blue smoke
More then likely needs rings. What year is it and how much does it smoke?
Old May 18, 2006 | 11:55 AM
Default blue smoke
it is a 1989 and it was said to have a new top end piston and rings, but i looked in at the piston when i pulled the spark plug out, and it deffinetly did not look new. it has tons of power but it smokes. it is starting to smoke more every time i ride it seems like. but i dont know. i would like to know before i go tearing apart. thx
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
