04 Warrior Fuse
Old May 20, 2006 | 02:56 PM
bighweel366's Avatar
Default 04 Warrior Fuse
hey my 04 warroir was working fine and then all of a sudden won't start, won't click, wont do anything. i think it is electrical because my lights won't turn on either. (the lights should stay on even if the bike isnt' running, correct?) i tried to follow the wires to possibly find a fuse but no luck. does anybody recognize theses symptoms or possibly know where a fuse is? thanx
Old May 20, 2006 | 04:40 PM
recon99's Avatar
Sounds like it might be the fuse. The fuse is one of the old style glass ones under the left rear fender, it's a plastic holder with red wires. I that recommend instead of getting another glass fuse, go to the auto parts store and get a regular blade fuse holder and the same size fuse originally in the warrior, just in the blade type instead. Cut out the old fuse holder and solder/crimp the new one in. The glass fuse holders aren't very good for off road vehicles because they hold water inside, then corrode and the springs and stuff rust apart and it doesn't make proper contact and can cause intermittent problems.
Lucas Bohanan
Sep 29, 2015 01:16 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
