Razr's for my 350
Old 05-21-2006, 05:18 PM
shroomfan419's Avatar
Default Razr's for my 350
i need new rear tires. (the front ones are still alright) would it matter if i only changed the rear and not the front? or should i get front ones even if i dont need them yet.
well i want the maxxis razr tires. and the stock tires are 20x10x9. so my question is should i just get the razrs 20x11x9 or should i go to 20x11x10 (which is what the guy at eastcoast atv told me to do) and whats the difference (pro's and con's) of 4ply and 6ply, and which would be better for my kind of riding..
i ride mostly on trails and there are alot of rocks at certain places (im a member at towercity and i go to the hatfield mcoy trails everyonce and a while) so thats mainly the kind of riding i do.
i also go to the track sometimes and im putting jumps in my yard so i still want to be able to jump and all that good stuff
any help is appreciated
-Andrew
o yea and what exactly does each number me in the tire mesurments _ x _ x _ ? thanks.
Old 05-21-2006, 06:24 PM
redwingsrule05's Avatar
I don't think you need much bigger tires, but the razr 2's are bad a%! I love mine!
Old 05-21-2006, 06:26 PM
i was looking at those. but the guy at ECA told me they wouldnt be good for what i want them for. they would wear down way to fast and not last as long as the 1's
Old 05-21-2006, 08:41 PM
recon99's Avatar
The numbering size for tires is Height X Width X Rim Diameter. For trail riding and rocks the 20-11-9's are definitely going to be better. The 10's will have a harsher ride, and you'll be more likely to bang up your wheels because of less tire sidewall. Plus, if you get tires for a 10 inch rim you'll also have to buy the wheels in addition to the tires. Go with 20x11x9 6 ply razrs. I've been to TCTRI, and you definitely want the toughest tires you can get for that place.
Actually, 22x11x9s would be better for tower city, they'll give you more ground clearance for those rocky trails, and will ride a little more smooth. On the other hand, the taller tires will subtract from your cornering ability so you'll have to make a decision on the compromise - handling vs ground clearance and ride.
And if you don't have one yet, get a good heavy duty full chassis skid. You want to protect that soft underbelly, a cracked engine case or broken frame will ruin your day and make the wallet hurt.
Old 05-21-2006, 08:50 PM
I have had my Razr 2's for about a year and a half and I ride almost everyday, and they still look like new they don't wear at all.
Old 05-22-2006, 09:40 PM
alright thanks guys
ill probally just end up get the 20x11x9 6 plys.
if anyone else has any info or suggestions post them [img]i/expressions/face-icon-small-smile.gif[/img]
also what price should i be looking for. they shop told me $80ish. but ive seen them online for $50ish.
thanks
-Andrew
Old 05-23-2006, 06:21 PM
fastestkidaround's Avatar
razr 2's or hole shot hd's or xcr's would be a great choice. Get 20x11's with 8, 9, 10 rims. The rims are up to you probably 9's would be a good choice.
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
bermbanger
05-05-2001 12:53 PM
Quick Reply: Razr's for my 350
