Wolverine electric start problem
Old Jun 23, 2006 | 09:04 AM
GlennJ's Avatar
Default Wolverine electric start problem
Cool, that's good to know that it pulls out pretty easily.
The battery I have is only a month old, so I should be set with that...hopefully!
Old Jul 9, 2006 | 12:01 AM
GlennJ's Avatar
I just wanted to update everyone on this.
I was able to remove the cross threaded bolt...which was only cross threaded on the very bottom, but it was also bent. How the previous owner did that, is beyond me! After the mounting bolts were out, I was able to pull the starter right out.
When opened up the starter, I was greated with quite a mess! There was this really odd grease/goo all over the brushes. I'd imagine it was what was left of the brush material that had worn off, mixed with a little oil. It looked like semi dried out grease.
I cleaned the brushes and brush plate with electrical cleaner. I then did the same for the communicator. After that, I sanded the communicator with a bit of 600 grit paper to shine it up a bit. I also cleaned out any gunk in the grooves of the communicator.
I put it together, mounted it and it worked! Hooray! So I guess a good cleaning is all it needed for now. I'm kidna perplexed as to how it go so dirty. All the seals looked pretty good to me. I an only assume a bearing in the starter was maybe overlubed a the factory? I'm not 100% sure.
Oh, the brushplate I ordered was on back order with no ETA. I cancelled the order and ordered just the brushes. Those should arrive next week.
Old Dec 30, 2015 | 09:39 AM
Dupey53's Avatar
I have a yamaha wolverine 350 an when i try to hit the electric start all i get is a click from the back of the wheeler anyone know what that might could be
Old Dec 31, 2015 | 03:34 AM
Like earlier posts on this thread mentioned, it can be a flat battery. If the battery is OK, check the terminals on the battery, solenoid and earth are clean and tight. Still no start? Get a 12v test lamp, connect one side to earth and the other to the wire running from solenoid to starter. Ignition on, press start button, if the lamp lights you have a faulty starter, if it doesn't, but the solenoid clicks, you have a faulty solenoid.
4xrider
Apr 10, 2017 01:36 PM
rmx251
Sep 10, 2000 11:40 PM
mrdci
Feb 7, 2000 07:16 PM
mrdci
Dec 4, 1999 11:03 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
