Need help with brand new YFZ450
Old 06-25-2006 | 11:04 AM
Scooter86's Avatar
Knows Old ATV Questions!
Default Need help with brand new YFZ450
Vem, The smell you are getting is normal for a brand new quad. It will go away after you ride it a few times. Actually, you get pretty much the same smell after installing a new exhaust or repacking the current exhaust, no biggie. Did you check the fuel petcock? It is kind of hidden up under the plastics on the YFZ, make sure it is turned on. These days, manufacturers have to sell product jetted a little lean to meet emissions, yours may be leaner than normal on the pilot and/or mix screw and is certainly worth checking out if it won't idle or run properly. Lastly, it is normal with the stainless header for it to glow somewhat. I also have had my YFZ jetted very rich down low and the header would still have a little glow if I let it idle for a while.
Old 06-25-2006 | 11:21 AM
squeege's Avatar
It will glow...even mine did on my kodiak 450
Old 06-25-2006 | 11:30 AM
enFORCER's Avatar
Originally posted by: vem
Another question...
So, If Im running lean... The bike is fine and I can ride it hard?
If the motor is a little lean it will run hot at times and boil over. If it is real lean you will burn valves and pistons. However I do believe Yamaha jets all their quad for 0-1500 ft above sea level. Take the quad out and ride it a few minuets and then take a look at the plug, if its snow white then your running lean.
Old 06-26-2006 | 03:20 AM
vem's Avatar
vem
Sorry to say but I felt off the bike doing a wheelie by pressing on the back brakes too hard. It resulted with me having a broken ankle. Now I have to wait till Thrusday to get surgery.
I didnt even got to put 10 mins of riddin. I should of wait till I felt comfatable to start doingf tricks.
But what a big difference going from a blaster to 450.
  #15
Old 06-26-2006 | 04:14 AM
BayAreaYFZ's Avatar
All the yfz's come lean from the factory. Just break it in and re-jet it you will be fine. pipe glowing is normal.
  #16
Old 06-26-2006 | 01:31 PM
silent101's Avatar
iv hears of dealer scams like this before, what the do is say you buy a quad they will load up a cheap modle or not the right one and send it to in the middle of the night or when you're not home and once you see it you tell the guy delivering that its not the right one and he says ok but i need you to sign this paper saying i came here and showed up. then you sign the paper and you are stuck with the quad.
  #17
Old 06-27-2006 | 08:55 AM
Scooter86's Avatar
Huh? He got the right quad, and it was delivered when he WSN'T home. Just someone at the dealership skipped out on the PDI since it doesn't run right.
Vem, sorry to hear about your ankle. Just do yourself a favor and let it heal before abusing it again, or else you may compound your problems later in life.
wendal
09-07-2019 06:46 AM
EIF
04-20-2017 07:15 PM
fredrikrosen
09-28-2015 09:58 PM
95scramblerruben1033
09-23-2015 06:29 PM
09-23-2015 06:23 AM
Quick Reply: Need help with brand new YFZ450
