Grizz throttle cable question
I bought a new '06 Grizz this past April and I was finally able to take it on some serious trail riding this last week (worked awesome!). On some sharp switchbacks when I would turn the wheels all the way to the left, the throttle cable would tighten up and it would want to accelerate. Is there an easy way to adjust that cable or is there something I should look for?
The manual says to adjust the free play ,it should be 3-5mm( 0.12-0.20 in.) At the throttle lever . Try to adjust it at the carb 1st if you cant obtain that spec. you can do it at the throttle lever adjustment also .I had to do it to mine . good luck.
GregM
Mar 6, 2018 06:53 AM
