2005 YFZ450
Old Jul 20, 2006 | 03:46 AM
  #21
2fun's Avatar
Default 2005 YFZ450
Originally posted by: 450YFZRIDER
I GOT A YFZ 450 ABOUT TWO MONTHS AGO AND THANKS TO EVERYBODY'S FEEDBACK I'AM GOING TO DO THESE MODS; TAKE OUT THE BUFFLE FROM THE MUFFLER, INSTALL K&N FILTER AND RETARD THE EXHAUST TIMING 1 TOOTH. I WAS WANDERING IF ANYONE KNOWS WHAN SIZE JETS I SHOULD BUY?
ALSO I NOTICED THAD MY YFZ BACKFIRES ONLY WHEN TORQUE BRAKING. I CHECKED THE AIR INTAKE AND HEADER FOR ANY LEAKS BUT DIDN'T FIND ANY. HOW DO I TELL IF IT IS RINNING TO LEAN OR TO RICH?? I TOOK OFF THE ASIR BOX COVER JUST FOR A FEW MINUTES TO SEE IF IT WILL FEEL ANY DIFFRENT, BUT IT WAS ONLY LOUDER, AND MAYBE LOST A LITTLE POWER. I WOULD APPRECIATE ANY FEEDBACK. HAVE A BLAST RIDING.
See my above post. Though it may not be EXACTLY what you want, it should give you a good ballpark setting. Then perhaps buy 1-2 main jets bigger and smaller to fine tune your top-end. I doubt you'll need a bigger pilot than a 45 with those mods, and the needle will probably be ok at the 5th or 6th clip.
If you bought an 06' YFZ, you will have to get a needle from an 04-05, or an aftermarket one.
I have the DR D pipe, K&N filter (with air-box removed), and cam mod, and I am running a 45 pilot, stock needle on the 5th clip, 172 main jet, and it runs extremely strong at sea level.
Hope this helps. [img]i/expressions/face-icon-small-wink.gif[/img]
salixair
Nov 3, 2015 08:25 AM
Sep 23, 2015 06:23 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
