RAPTOR 660R WTF IS WRONG
my 04 raptor 660R is messed. i took it out of the shed today warmed it up put it in first and it had nothing... it would go like 3 mph and then it would just choke on its self and backfire... got no clue whats werong with it but i have checked the spark plug and cleaned that up a bit... put some drygas in the tank...it was warmed up plunty.. the airfiler and oil were recently changed and it ran fine after i changed it so if anyone has a clue wtf is going on tell Me please... thankyou.
well im going to take it to the shop tommorow but my friend said it might be a clogged jet and someone else i know said it might be the e brake...if its the e brake can i fix it at my house?
yea right now it idles ok... and will allow me to give it a bit of gas but if i give it to much it boggs down and chokes on it self... i havnt done it yet but im shure if i went full throttle on it it would shut off.
same thing that happened to mine im positive its a clogged jet. take of the carb clean it all out and clean out your filter and buy an inline filter . it will run fine after that promise.
EXACT same problem i had a week ago.
you have stuff in the bowl that is getting clogged in the jet.
a clogged jet (most likely pilot since it is lowest in the chain) it would fix itself above that...
a parking brake issue wouldn't get better at all... and only allow the rider to go about 1/32 throttle when it is engaged before it wants to engage
yea my friend has an issue with his jets were they were clogged and it wouldnt run well but i just went opur side and i pulled what i think is the parking brake rev limiter thing and it runs great i dont know if its bad to do that but it runs like normal now so yea is that bad or not?
