hill climbing 02 warrior
Old Jul 10, 2006 | 02:16 AM
gt350tsc's Avatar
Default hill climbing 02 warrior
i have a 02 warrior any advice on hill climbing with it.
Old Jul 10, 2006 | 04:13 AM
fastestkidaround's Avatar
some good tires. and keep power on and lean forward. lol
Old Jul 10, 2006 | 08:48 AM
recon99's Avatar
^that about covers it^ Also, make sure you're in a low enough gear that you're going to be able to pull the entire hill without downshifting.
Old Jul 10, 2006 | 10:40 AM
yep i thought it did. yeah u dont want to kill it when u downshift. i was climping a huge rock pile like 100 ft.+ and i dowshifted some how it killed it. then i pulled in the clutch and brakes to easy down and then all the sudden like my rear tires would not brake and the fronts slid so since i jsut started u leaned forward and let out the clutch and going backwards it started. going backwards i was like how the he!! did that happen? i dont know but i got down safly and have not gone back. lol
Old Jul 10, 2006 | 11:35 AM
YamahaRider8998's Avatar
one good peice of advice is if you get stuck on the hill and start spinning dont panic, just keep leaning foward and shift your weight back and forth to try and get some traction, make sure not to lean back and foward or else you might grab and flip back, rarely happen on a warrior cause its so front heavy but it has happened to one of my freinds.
dannytas
Sep 26, 2017 06:31 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
