Yamaha Warrior starter relay
Old Jul 11, 2006 | 07:53 PM
Smooth's Avatar
Default Yamaha Warrior starter relay
I just brought this and i'm trying to crank it. When i push the starter button it just click. So i have replace the relay two time, and i get the same thing. Is there a way to bypass the starter relay(temperary). I don't want to push it off....
Old Jul 11, 2006 | 08:10 PM
Budwiser's Avatar
It sounds like a low battery
But you can just have 2 wires going straight to the starter. It passes everything and tells if the starter is still good, and it allows you to work from there. I believe the neg. to the screw on it, and the pos. to the starter case.
Old Jul 11, 2006 | 08:16 PM
YamahaRider8998's Avatar
you take a thick wire or jumper cables and touch the positive side of the battery to the nut on the starter relay that goes away from the battery. bypassing the starter realy which mean right when u touch it it cranks. if it doesnt crank the starter is bad or battery is dead, if it cranks alittle the battery might be low. That happened to me before, also check all wire between the starter relay and the starter cause some might be screwed up.
steve
Reactant
Mar 30, 2022 02:08 AM
ghost civic
Jan 15, 2020 07:43 AM
Reactant
Jul 16, 2015 10:29 PM
ghost civic
Jul 15, 2015 10:48 PM
cornermike
Jul 8, 2015 11:44 PM
