Rear Diff Drain?
Any other wolverine owners stripped out the drain on the rear differential? Mine was a bit rusty from water sitting in the gaurd and it stripped out very easily like all the other bolts/drains on the thing. Any tips on getting it out? Also does it hurt to just drain it out the filler, what i did was throw my winch around a tree branch and hang it up for a bit and i think all the fluid drained but not sure.
The best thing you can do is buy a nice 6 point metric socket set. Even the big 19mm drain bolts will strip out very easy using a 12 point socket. Using an adjustable wrench, SAE socket, or anything like that will almost always turn out bad. For the striped bolt... first squar off the bolt head a bit with a hand file and then try a nice vice-grip.
well it wold be alot better if i could use a socket, but the dam thing is an allen head bolt, retarted if you ask me. any other wolverine owners have similar problem? im gunna try to heat it up and see if that will break it.
