raptor 660 is screwed
Old Jul 15, 2006 | 08:37 PM
kny660's Avatar
Default raptor 660 is screwed
ok, DriverDoyle if you get this, i need your help... my raptor is friggin screwed.. i had it running like a champ 2 days ago, then all the sudden it bogged, seemed like it was starving for gas, then died.. now today, i go to start it, and it feels like there is no compression at all, it just spins and spins, but its not the woodruff key, i was wondering if the one-way could be out because every few spins i can here it compress somewhat, and when we pull it, it does the popcorn exhaust bit when i flood the hell out of it... any ideas? this thing is on my last nerve..
Old Jul 15, 2006 | 10:39 PM
texraptor's Avatar
Have you done a compression check.If it was running and it started to bog down.I don't think it could be the one way.Check the breather vent on your gas cap.If it is plugged it would vapor lock the fuel system.
Old Jul 15, 2006 | 10:50 PM
kawiking's Avatar
check your air intakes on the carb. my kfx was running real good one day,stopped turned it off ,went to move it about 15min later and it wouldnt start. finally figured out the tube from the carb to my air filter(clamp on) came loose. just barely!!. put it back on and tightened it tight anf she started right up. good luck.
Old Jul 16, 2006 | 04:45 AM
kny660's Avatar
thanks guys, i'll give it a try
Old Jul 17, 2006 | 01:17 AM
kny660's Avatar
ok, update, did all the above, everything good, it shows nothing on the compression meter, sounds like it turning over, and part of the assembly is eg. timing marks, yet its not pushing the crankshaft over and compressing, so i'm convinced it's the one way.. i've heard not to go with oem, so what would you guys recommend?
Old Jul 17, 2006 | 01:40 AM
DriverDoyle's Avatar
Sorry iv been busy all weekend..It looks like to good buds of mine got you going txraptor and kawiking...Here is the starter clutch i have in mine..I think its the best one made..LA Starter Clutch
Old Jul 18, 2006 | 07:01 PM
kny660's Avatar
dude... your the man
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
black_thunder
Sep 22, 2015 07:59 PM
