warrior performance
Old Aug 7, 2006 | 05:06 PM
ZapooMafoo's Avatar
Default warrior performance
What is holding your air filter in?
right now there is a block of wood which keeps it tight and my seat.
is the silencer on a warrior, before the muffler, in the pipe part of it?
and will that make it louder if I remove it.
also, if I get a k&n filter should I get a pre-filter too?
Thanks.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 7, 2006 | 07:48 PM
ZapooMafoo's Avatar
And is it possible to get a yoshimura cherry bomb for a warrior or is that only for the suzuki?
Thanks.
Old Aug 7, 2006 | 10:19 PM
ZapooMafoo's Avatar
pls reply tonight im leaving for four days tommorrw
Old Aug 11, 2006 | 09:41 PM
ZapooMafoo's Avatar
its been four days and no replys?
someone has to know about the filter and bomb.
Old Aug 11, 2006 | 11:29 PM
  #15
bombrider04's Avatar
driver doyle gave you alot of choices so what I have done and do to my quads is wait and save up my money until I can get one of the best items becuase I don't feel like getting something cheap at the time and replacing it...I would recommend the K&n airfilter with a prefilter,a good exhuast hmf,yoshi,white brothers or any others depending on where you ride and the db range so you don't get into trouble since both of those exhausts are loud not sure if they sell em in a full system for your quad though.Then when you get the exhuast and filter get some new jets into that carb...Last I would change your tires to something that is good in dirt since that seems like where you ride holeshots or razr's then last I would change the sprocket...I don't know if I would mess with the cam yet but if you do put it in about the same time at the exhuast...so pretty much everything driverdoyle said to do but thats the order I would do it in
Sep 30, 2015 01:37 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
jankerstien
Sep 21, 2015 03:09 AM
