top end gaskets for warrior which ones?
im getting new gaskets for my warrior and im wondering if the cometics will work alright ? or the tusks ? or is there something else i should be going for ? thanks for any help
Definitely stay away from the tusk gaskets. Stay away from anything tusk that is time consuming to replace, because a lot of their stuff doesn't hold up like it's supposed to. I had one of their tie rod ends on my warrior, the thing may have lasted for 15 hours of riding before it got so sloppy that the ball almost popped out of the cup. The other 3 tie rod ends are still the stock ones, with hundreds of hours on, and they are still like new, so there's a comparison of tusk's quality. Some of their products are ok like the nerf bars and gas caps, but you usually get what you pay for.
I'd recommend Cometic or Vesrah gaskets, i've used both of those and never had one fail.
You get what you pay for. If it was me, i'd get something with a good reputation and not have to worry about how long it will last. With as much work as there is involved with it, i'd rather spend an extra 10 bucks now and save myself the labor and downtime later on. You shouldn't have any problems with the Cometic gaskets, I never had a problem with one, but given the choice between the 2 i'd pick the Vesrahs just because that's what the local powersports shop uses in all their race bikes and doesn't have any problems.
jrooker6
Apr 23, 2016 07:36 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
