Blaster exhaust
Old Aug 18, 2006 | 12:41 PM
blasterboy68's Avatar
Default Blaster exhaust
What is the best pipe for a blaster?
Old Aug 18, 2006 | 08:41 PM
Boomer2's Avatar
It depends on what kind of riding you do. Toomey provides good topend, so it is good for dunes, hillclimbing. FMF and Pro Circuit are good trail pipes. Project Blaster Phatom, LRD, and Dynoport provide good mid range so they are good MX pipes. You have to decide what pipe is best for you. The Toomey pipe actually only makes only a few more HP than a FMF.
Old Aug 18, 2006 | 09:27 PM
well, right now I have a FMF powercore2 pipe on and I would like a little more low end power
Old Aug 19, 2006 | 06:05 AM
JLsparky7's Avatar
hey you ^ welcome to the forums...
My cousin has an FMF pipe and powercore 2 and its a big sted up from my other cousins stock blaster.
Old Aug 19, 2006 | 11:24 AM
Boomer2's Avatar
To get more lowend you could mill the head for compression, Get some aftermarket reeds, reed spacer it shifts the power band to the low end, or advance the timing 4 degrees. These are all cheaper than a new pipe.
Old Aug 20, 2006 | 02:16 AM
drumpro's Avatar
FMF Gold Series Fatty and Core 2 Silencer or Toomie B-1
Old Aug 20, 2006 | 12:50 PM
fastquad02blaster's Avatar
If you want more right off an idle power you might try moving the clip on your carb needle down one notch closer to the point. Someone on here told me that and it really worked. Mine from first to second and second to third will try to pull the front wheels off the ground. It really hits hard now.
Old Aug 21, 2006 | 12:00 AM
Boomer2's Avatar
drumpro what kind of riding do you do? One thing that is good about a toomey is they sell a kit that has the jets you need, aftermarket airfilter, vents to open up the airbox, and of course the pipe. You can't really go wrong adding a pipe to ablaster unless you get a DG. They all improve the performance of blasters.
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
