Blaster won't idle
Old Aug 25, 2006 | 11:04 AM
MWMKX250's Avatar
Default Blaster won't idle
Blaster runs fine off idle it just won't idle at all. Cleaned carb 2 or 3 times...any other ideas/suggestions?
Old Aug 25, 2006 | 12:29 PM
Storj's Avatar
There is a screw on the side of the carb its basicly thew idle adjustment screw turn it all the way in then back it out 1 1/2 turns if your blaster is stock. If not then you can just fiddle with it and figure out what works best.
Old Aug 25, 2006 | 12:40 PM
MWMKX250's Avatar
Did that...all the way in still won't idle.
Old Aug 25, 2006 | 12:56 PM
Storj's Avatar
you then need to back it out 1 1/2 turns.
atvmike92's Avatar
Have you tried rejetting it?
Old Aug 25, 2006 | 12:57 PM
Storj's Avatar
Yea you may also have clogged jetts.
Old Aug 25, 2006 | 10:19 PM
Boomer2's Avatar
Does your blaster still have the tors system on the carb. It may be causing the problem if it runs but won't idle. I would remove it. You have to buy a kit that has a new cap and throttle cable. You also have to splice the wires inside the thumb throttle. Here is a discussion about it. TORS removal The screw on the side off the carb is the air screw, the idle adjustment is the knurled **** on top off the TORs on top off the carb. That is if you have a stock carb with the TORS
Old Aug 25, 2006 | 11:45 PM
TORK's Avatar
I would bet that Boomer2 is right on the money. We saw this alot when I worked for a Yamaha dealer.
Old Aug 25, 2006 | 11:59 PM
JLsparky7's Avatar
you might not even need the kit, i didnt on my shee. Try disconnecting it.
Old Aug 26, 2006 | 12:28 AM
Boomer2's Avatar
You can probably diconnect the wires on the cap and splice the wire in the thumb throttle, and override the TORS, I wasn't as informed when I did mine.
franklyme
Oct 21, 2016 07:18 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
