Y2Kodiak blowing oil
Old Dec 3, 2000 | 09:19 AM
Trailmen's Avatar
I also have the oil coming out from the hose that is under the gas thank its the one coming from the rear diff. could it be there is water in it
Old Dec 3, 2000 | 08:41 PM
stormy's Avatar
I read a post awhile ago about someones kodiak blowing rearend oil up through the breather hose but I cannot find that post. Mine is also doing it now and I was wondering if I put too much in when I changed it. I filled it up to the edge of the filler hole (bottem thread) like the manual said. I remember the post saying that maybe there was water in the rearend that would cause excess fluid which would cause it to blow out the breather. What else would cause it? My rear rubber boot (around the differential?)did have a small hole in it but I repaired it with silicone. If that was leaking could it cause water to enter the rearend also? Does it look like much of a job to replace the boot?
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
franklyme
Oct 21, 2016 07:18 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Hw00d
Sep 10, 2015 08:53 AM
