Advancing timming on the banshee?
Old Sep 8, 2006 | 03:34 PM
JLsparky7's Avatar
Default Advancing timming on the banshee?
What exactly does advancing the timming involve and what do it accually do? Considering doing it this winter when i get pipes, reeds, and shave the head.
Old Sep 8, 2006 | 10:21 PM
Boomer2's Avatar
I know for a blaster you can get a degree key from, Vito's, or a adjustable stator, or make your stator adjustable youself. Any of these ways you will have to remove the flywheel.I think it's the same for a banshee. The degree key is just a off set woodruff key that goes on the shaft to hold flywheel in place. I think Vito's has a degree key and adjustable stator for the banshee. Making your stock stator adjustable is probably the cheapest way. I know how to do it for a blaster, but not a banshee.
Old Sep 9, 2006 | 02:05 AM
kawiking's Avatar
go to rick stator .com , $30---- i believe it gives you more top end or helps. retarting is for low end. i think ,good ? !! everybody (and me) has theirs at +4, mine is 4 1/2 i think.
Old Sep 9, 2006 | 04:49 AM
JLsparky7's Avatar
K ill look into that. Thanks.
Old Sep 9, 2006 | 01:59 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i think my buddy runs his at +5 and he custom cuts all of them himself
Old Sep 10, 2006 | 11:25 AM
RDZ350's Avatar
It's easy to do.Just buy a timing plate like they said.Remove the flywheel and take off the old plate.Replace it with the new adjustable plate.Set it with the middle of where the 2 case 1/2's meet.
Most do run it at +4 that use gas.Don't think "I'll just put it on +10 for more power".
On my alcohol banshee,I run it at +8.
You probably won't tell a big difference,but it does help a little.
Old Sep 10, 2006 | 07:14 PM
kawiking's Avatar
dont get the degree key, spend the extra $10 and get the plate.
Johnny Mac
60
Dec 14, 2019 06:13 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
