warrior gas tank
Old Sep 13, 2006 | 02:25 AM
olwarrior's Avatar
Default warrior gas tank
Ok so went riding for the first time with the warrior this weekend. Trail riding with my dad, while i ran out of gas quick. NO leaks my dad still had over half a tank(honda foreman450) is something wrong?? do they make a bigger tank for the warrior????
Old Sep 13, 2006 | 09:08 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
how long did you ride?? how much time were you at/near WOT or at idle??
yes they make bigger tanks
Old Sep 13, 2006 | 02:32 PM
JLsparky7's Avatar
Were you doing alot of wheelies? Your carbs drain if you do a wheelie for a long period of time.
Old Sep 14, 2006 | 12:11 AM
olwarrior's Avatar
3 hour ride no whellies. where can i get a bigger tank??
Old Sep 14, 2006 | 12:28 AM
recon99's Avatar
Something's not right, I can do a combination of hard riding and trail riding for at least 6 hours on a single tank before hitting the reserve, and i'm not exactly stock anymore. When I was mostly stock, including the stock carb, I would be hard pressed to run that tank dry in a weekend of trail riding.
IMS does make a larger fuel tank for the warrior, I think it's 3.8 gallons instead of the stock 2.4 (I could be wrong on both of those numbers but I think i'm close). They run somewhere in the $200 range.
Before I spent any money on that, first i'd try cleaning out the carb, focusing mostly around the float valve. If that gets stuck, then you could have been dumping fuel straight through the carb and out the overflow tube. It's normal for a few dribbles to come out of the overflow line when riding, but not too much.
Old Sep 14, 2006 | 02:28 PM
rappygonewild's Avatar
ims makes a bigger gas tank.
somethings wrong my bro can ride all day on his 01 warrior and never fill up.
Old Sep 14, 2006 | 02:56 PM
olwarrior's Avatar
Ya i thought there was something wrong. I planned on pulling the carb soon and checking it anyway because it cuts out on me and sputter sometimes it was a dune quad for 18 years and i'm sure there is sand in the carb and the floats are probelly stuck. so thanks. It sucks having to get towed back buy your dad, and then getting stopped by the ranger and getting in trouble for not having tags or plates.
Old Sep 14, 2006 | 05:11 PM
Baja226sport's Avatar
Defintiely check the carb. Mine got some crap in it last winter and the float got stuck and unless you were looking under the swing arm where the overflow goes you wouldn't notice that the whole time you are riding it is dumping out all your fuel.
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
wrencher82
Sep 24, 2015 03:39 PM
