BANSHEE REBUILD?!?
Old Dec 6, 2000 | 05:43 PM
300exPAUL's Avatar
well i might be buying a banshee fairly new with a blown engine for 400.oo bucks.
now to my question how much would it cost to completly bebuilt a banshee from top to bottom, what would i need, and what would it cost?
Old Dec 7, 2000 | 09:40 AM
sAyIt_fmf's Avatar
That depends on what you really need....
If you need a crank, bearings, seals, pistons, pins, rods, gaskets, gears, springs, cases, pump..can go on and on. Your looking at a good amount of money. I can estimate $2000 easily by the time you factor in labor. Probably much more than that.Depending on the mods while it's apart.
If you have someone to do the work..maybe less.
Are you sure it needs a rebuild from top to bottom?
Old Dec 7, 2000 | 10:22 AM
rawze's Avatar
IF YOU DO IT YOURSELF IT'S NOT BAD - I DID MINE FOR ROUGHLY $600. WISECO CRANK -PISTONS-30 OVER BORE- GASKETS-ETC.
RICK
Old Dec 7, 2000 | 12:40 PM
sAyIt_fmf's Avatar
$600?
well...I guess if you can get the parts for that cheap....And do the labor yourself. I can't imagine a bottom and top end for that price...But..I guess I am wrong.
I know it is possible to do the top end for a couple hundred. Cranks usually run around 300..unless yours is rebuildable. Transmission work is not cheap.
Old Dec 7, 2000 | 12:47 PM
RoostKing's Avatar
At any rate, BUY IT!!! For $400.00 thats a steal.
RoostKing..
Old Dec 7, 2000 | 02:14 PM
rawze's Avatar
new crank w/ bearings $350-piston kit $125-gasket kit, complete $35-if any tranny parts are bad check www.atvsalvage.com. i bought tranny parts from them to redo mine. used parts but good price. it's alright to buy used gears
Old Dec 7, 2000 | 04:17 PM
3o0eXpAuL's Avatar
Yes it is a great deal, and my dad rebuilds car engines and mottor cyvle engines so hes gunna do it for me.
Old Dec 7, 2000 | 09:12 PM
3o0eXpAuL's Avatar
so what would the price be to rebuilt the top/end of the engine if i build it myself with the gasket,crank,weisco piston , ect ect ect
i know it probobly will be more than what i am planing on baying for the bike but as long as i get her runnin.
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
