sudden acceleration
Old Oct 13, 2006 | 11:58 AM
sharktooth's Avatar
Default sudden acceleration
has anyone experienced a sudden acceleration? i was riding a kodiak450, turning slowly to the right,barely touched the throttle and it just took off. i fell off and it went 40' or so further and finally stopped. this was not a stuck throttle.
Old Oct 13, 2006 | 01:21 PM
paintballbanshee's Avatar
how long have you been riding? possibly you just need to get used to it???
Old Oct 13, 2006 | 01:42 PM
bombrider04's Avatar
if its accelerating when you turn then that means the throttle cable is getting pulled when you turn causing the quad to go (the same as when you push the throttle with your thumb). Just check to see how tight the cable is when you turn and adjust it so it won't be so tight and you should be fine.
Old Oct 13, 2006 | 03:41 PM
JLsparky7's Avatar
I experience sudden acceleration everytime i hit the throttle [img]i/expressions/face-icon-small-smile.gif[/img]
On a serious note, bomb is right.
Old Oct 13, 2006 | 04:03 PM
ClipClop's Avatar
Same thing happened to me on my son's baby rappy. I cleaned the carb and put it back in. I was sitting on it while fine tuning and when I pushed the handlebars one way it would rev and the other way come back down. Try That... (in neutral) If you can control the engine speed by turning the handlebars you need to lengthen it until it goes away...
Good luck,
Chuck
Old Oct 13, 2006 | 09:26 PM
sharktooth's Avatar
thanks for the reply,but are you sure that the 2006 model has a cable. The exact same thing just happened to a friend of mine. did it 3 times. took off when he barely touched it.
Old Oct 13, 2006 | 11:20 PM
ClipClop's Avatar
I'm not a "Quad Master" but I have never heard of one not having a throttle cable. Have you tried what I suggested? I would give the same answer to the other thread where you mentioned it. The steering is the only thing I can think of that will tweek the cable like you described.
Good Luck,
Chuck
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
